here's possibly the heaviest AA i've seen. after folks were talking about having a 3rd channel for an elevator, i thought i'd try the BladeRunner RX i've got sitting around. i put in two 7mm SS motors, a .6 gram actuator for the elevator, and the Mini Rescue BladeRunner lipo. i flew it for about 4 seconds, which happens to be the exact amount of time it takes to realize that you put the left motor on the right, and the right motor on the left, and that right hand turn you just tried to make is actually a hard left, which pile-drives the plane into the ground
the crash broke the verticle stabilizer and tore the leads off a motor, but it'll be fixed up for tomarrow.
this thing weighs 25.9 grams, and has tons of thrust, and with those two things, it should be able to take on 15 mph winds or higher.
nick
