RCU Forums - View Single Post - "Range" Checking your Plane
Old 01-01-2003 | 10:57 PM
Crash Master's Avatar
Crash Master
Default "Range" Checking your Plane
Keep in mind that the 100' is with the antenna collapsed. Once the antenna is fully extended, the range will/should increase significantly. You should lose sight of your plane before it flies out of range.
Just my .0002,
