RE: Recording the sequence
it would work but thring to work out the intervals between each manuver. cause some times due to wind or what ever it may take a little long to finish the loop or the cuban so you have to think about those things. cause what if you still doing a manuver and then it calls it too soon then you teing to fly that manuver and then tring to remember the next or what if you finish a manuver real soon and you need the next called right away and it still hasn't called it??? just alot of varabils to think about. i fly basic also. i also made my own manuver list so my caller would say what i exacly want to hear. cause i cn never remember which way a reverse or normal cuban goes. so i right it out what i do first like on a reverse cuban i write 45degree up line with half roll. i don;t put the loop pat cause i know it's a cuban i just need to know what to do first. like for a regular cuban i write half loop first with a 45 down line. i then would take this pocket call sheet and pin it up on my antenna and after each manuver while in the straight line between things i would just glimps down and see what to do. now i only do thing ever now and then when i fly alone. i hope some of these ideas helpss!!!
mikey
