ORIGINAL: dick Hanson
Oh oh
the plane does not know anything about headwind or cross wind
it senses neither .
If you try to change over the ground path or relative speed to a point on the ground-then you deal with the wind
I read and read your last post - it seemsyou believe the wind (a steady wind) affects the angle of the crarft -as it flies .
It does not.
Only YOU trieng to orient to a ground point - will affect needed positions or recovery to a previousposition
A neutral plane simply keeps on going where it is pointed
a as- stable plane -requires constant inputs
a self stabilizing design - of course - given time- will correct to a level flight attitude-all on it's own hook- if it doesn't smack something first.
I have built all three types and they all have good reasons for existing
Errr, you weren't replying to me, were you? Cuz I'm right with you on this. Your post says "in reply to mesae" but you didn't quote anyone.
