sctcrash... My Carb. rotor/barrel stop screw came lose once on my Mag 91, Not
sure what if any problem it caused, except for the barrel falling out[
].. Luckily
it did it as I put the plane on the table, So nothing got lost..., You may also want
to check both your needle/seat.. It could be worn, depending......
Well, just made some checks and small repairs to the "Do"... I had to C.A. the
stringer<??> turtleback... I broke the top one in a couple places picking the plane
up[:@]... Well, a fellow member did it as he asked too carry the plane to the runway
as I was ready to fly...( He still asks to carry the plane out, But I say no now stating
I have to stick to my routine, As the rag in my back pocket to prevent problems)
Also found my belly pan coming lose at the wing bolt end hoping that was my added
harmonics, will find out in the AM... Ohh, yeah I also had to repair the Lt. elevator
leading edge end... Last time out I did a touch and go, and I pulled into a hover at
lift-off.... But I still had it on high rates.... She stood up fast, surprizing it did not tear
it off
It's been a bit since I took her out, but I have to give the other a rest....
Hope the Grandkids will let me fly
