RCU Forums - View Single Post - TOP FLITE SPITFIRE BUILD
Old 07-18-2006 | 05:38 PM
  #58
saramos's Avatar
saramos
Default RE: TOP FLITE SPITFIRE BUILD
IL2,
Thanks for the comments.
I have only run the RCV on the bench with a 2 blade. I have not decided if I will use a 2 or the 4 blade for the maiden. I think I'll do some ground taxiing with the 4 blade and then decide.
Here's some photos of the cooling system I'll be experimenting with. I have not run the engine installed in the plane yet. I will post results when I test it out.
Scott
ID:	493381   Click image for larger version
ID:	493382   Click image for larger version
