RCU Forums - View Single Post - high temp resin ? epoxy ? ( for pipe)
Old 07-19-2006 | 01:34 AM
digitech
My Feedback: (10)
Default RE: high temp resin ? epoxy ? ( for pipe)
ORIGINAL: wojtek
just found out EZ-lam is good up to 200c .... hmm .. i don't know if that would be enough ?? also, it needs to becured at a similar temp... anyone know of anything that would not need to be cured at such a high temp ? and/or that can withstand higher temps ?
Voy
no problem Wojtek
our L-39 has a composite outer pipe over the ss steel pipe
the lenght is over 800mm
never had a issue .
