RCU Forums - View Single Post - TOP FLITE SPITFIRE BUILD
Old 07-19-2006 | 11:38 AM
  #65
saramos's Avatar
saramos
Default RE: TOP FLITE SPITFIRE BUILD
Depending on where you are mounting the fan and batteries, the extra weight might be an advantage. A lot of warbirds require the addition of weight to the nose to balance. For example, in my case, I'll need around 2 lbs in the nose to balance. The added weight of the DF, controller and battery will offset some of the lead I will need to add.
Scott
