Yeah, I moved the battery pack up. I have some lead if all else fails
. Anyway, as far as the pushrods being routed wrong, it was not a matter of the holes not being in the right place in the firewall, it was simply a matter of the pushrod sleeves being routed to the wrong holes. The rod that the antenna was supposed to go through was positioned where the elevator should have been, and the elevator was where the antenna should have been.
I did send CG an email about 3 days ago, and never heard back. Plus all of the work I had put into this thing (I was almost FINISHED when I discovered this problem), there was no way in ummm hell that I was going to send it back, the tail section had been epoxyed, etc.
Sorry for the bad spellings
Jody
