RE: E-FLIGHT BLADE CP
I've been reading these posts and tried the fix for sticky collective. When I was done I noticed more of a sticky problem then I had before. After checking the CP I noticed that there is a ton of play in the blade grips from side to side (Outward / inward) is this normal? how much play should there be with the blade grips to the center shaft? also why do I have more sticky after the mod? any help is greatly appriciated
Thank You,
