RCU Forums - View Single Post - How to replacei nner shaft? Blade CX
Old 07-19-2006 | 08:05 PM
Gonwee
Default RE: How to replacei nner shaft? Blade CX
Did you loosen the screws on the bottom gear? Just a few turns should pull them out enough to get the shaft out. To much and you'll pull them out of the gear(which you then have to line up becauses it will fall of the gear)
