Help needed!
i would like to thank you guys for taking the time to answer to my quesition. I have allready designed the fuselage (Starting with the easy part first), it has a length of 1.8 m and the target weight will be around 8.5 kg including wings,retracts,engine,e.t.c.
I am aiming at a 1.7 span wing with zero incidence regarding the thrust line at a stab with a negative 1 degree. I am designing a system that will allow two separate designs of wings to be fitted to this model on to serve as a forgiving trainer wing and one as a high speed wing (both with the same incidence,but different sections ).Firstly i want to design the trainer wing.What i want from this wing is to allow low speed landings and low speed flights. What would be an apropriate airfoil/s?
