RE: nitro fuel delivery
Take the head shim out and retune it. Do not try squeezing out every last bit of power because it will have less than higher nitro fuel. If the 10% fuel you have run has more oil in it than the car fuel you previously ran, then yes it will run a little hotter.
As long as you tune it so the top end does not sag or fade away on a wide open strech and the off idle mixture performance is crisp and clean, no bogs or hesitations; then you will be fine, it will not be too lean and you will not hurt anything regardless of temp. Crisp and clean but never too lean.
