RE: ST body
Hey Man,
I just ordered that body and I plan on putting it onmy Marder. I talked to the owner and I was told it would fit with minimum modification. I ordered 2 long post that I'm going to mount next to the shock towers, however; you can use the one center post that would mount to the bulkhead brace. You can also go one step further and add side mounts, I plan on using the same method as on MT and MB and put caps to cover the other holes in the body which a standard leopard mount points. I'll post pics when I'm done, I'm hoping I get the body today.
C-One
