RE: PRECISION AEROBATICS EDGE540T
Should have sold the plane like rbxbear44 did. After 15 flights I replaced the landing gear, bent almost everytime I landed. Replaced gear with Graphtech carbon fiber landing gear. After 80 flights the landing gear broke off, Block that holds landing gear on is glued to two formers that are 1.5" apart. To much leverage for the small block to hold the gear on. On the 112 th flight, Straight and level at 1/3 rd. throttle the tail started flapping. Almost had it turned around to land and tail broke off. Plane went in, nouthing else was hurt.
David
