RE: Showtime
Fury:
I'm not that experienced a pilot, so take that for what its worth, but I saw the deflection amount and the size of the surfaces and thought no way will I be able to fly this at the recommended rates, so I have my high rates set to the low rates with about 60% expo and the low rates are set to about 25% with about 65% expo. I only have a few flights on it, but I will tell you that the high rates mentioned above are not that crazy on the plane -- I was surprised. My low rates make it very easy to fly around, but still maneuverable -- the roll rate is still quick and the elevator has good authority at the 25% -- The plane is able to do all aerobatic maneuvers (not 3d) at 25% of the recommended low rates, but I was able to land and take off at the recommended low rates (my "high" rates). Hope that helps
