yeah, do the fuel tubing like alvinl says. I had that happen one time and lost the dogbone in the snow [
Also, you can tighten up the balls that go into the end of the A arms. This will bring the wheel hub in closer to the truck so there is less slack in the dogbone. Just make sure to readjust your tie rod afterwards.
