RCU Forums - View Single Post - JetCat P60 Oring Replacement DIY
Old 07-20-2006 | 07:49 PM
Jason Burg
Default RE: JetCat P60 Oring Replacement DIY
No sir. The warranty will not be voided if you replace the O-ring the way i descibed. Infact, the method explained was the specific method I use. The reason i say not to remove the starter is because the alignment of the starter to the compressor nut is critical. Any change in this alignment may casue problems with the bendix engagement / disengagement. If the starter bendix does not disengage at the proper time (about 33,000 RPM), the starter becomes a generator and sends a very unwanted current to the ECU power board. (as most of you know, the only difference between a starter motor and a generator is the direction of current supply) So if any of you want to change a starter O-ring, and are NOT SURE what procedure to follow, call JetCat and i will talk you through it.
Jason Burg / JetCat USA / Technician
