RCU Forums - View Single Post - HOW DO YOU DRIFT WITH JUST 2WDRIVE?????
Old 07-21-2006 | 12:23 AM
  #82
color0's Avatar
color0
Default RE: HOW DO YOU DRIFT WITH JUST 2WDRIVE?????
2WDrifter, Xmods are still crap, unless you upgrade the electronics to something proper. Even an Iwaver board, or preferrably a Mini-Z board will do.
I'm still working on my MR02, the setup goes as follows now:
Front tires: drift, sanded down, adapted to Square inch-ups
Rear tires: GPM 55
Wheels: Square inch-up for MR02
Front spring: Atomic disk damper spring, red (medium)
Rear t-plate: 3racing medium
Rear damper: Atomic disk damper, duralube, green (soft) springs both sides
Differential: GPM 12 ball
Motor: hybrid, uses Hyper dash 2 armature
I'm taking short video clips each run, so that I might have a long, well-edited video to show you guys by the time school starts. I can keep the tail out at 40 degrees or more, for 10 feet or more, so I know I can do this. If I had more space to run, I'd bring out the mod car and go 20 feet each drift; but right now the mod car's useless.
