RCU Forums - View Single Post - Where to get scale C/L kits
Old 07-21-2006 | 11:49 AM
clscale-RCU
My Feedback: (7)
Default RE: Where to get scale C/L kits
Just a quick note for the conversion process:
1) adjustable line guide
2) Bellcrank can be anywhere, but typically 1" behind the CG is what I typically do
3) Put the rudder at nuetral, in fact I have one sport model that has no rudder at all.
4) Make the tailwheel or nosewheel adjustable so that you can get the model to taxi correctly
5) I set the stabilizer at zero degrees of incidence. Some RC kits have positive incidence in the fixed stabilizer.
6) Engine does not need down or outboard thrust
7) make a box in the right wing to adjust the wingtip weight
Good luck
