RE: Airsail Chipmunk build. Need advice.
It's actually not quite possible to tell you that. The thing is, the horizontal stabilizer tapers in thickness from the base to the tip. Only thing I remember is that the sheeting is 1.5mm thick (about 1/16", the kit is Metric). I can try to measure the thickness at the base and at the tip when I get home, but I'm not sure how accurate it will be.
