RCU Forums - View Single Post - Showtime
Thread: Showtime
Old 07-21-2006 | 05:41 PM
  #1761
Banche
Default RE: Showtime
I have been flying for a while, and this is one kickass plane. Even in the 105 degree F heat. Mine flys perfectly strait and the knife edge is awsome. It locks into a hover really well, I love how this plane TR's I brought it down infront of me for like 3 minutes today. However if the nose gets off going to the side about 5 degrees, you cant get it back into the hover with the rudder you have to roll and use the elevator. Its only like that for me though because I am using a saito 100 that has not been run for over a year and a jug of 30% that has been sitting half empty for over a year. Oh and the glow plug probably needs replacing, I can only get about 9400 rpm but that should change.
I have all the rates and throws just the way I like them. The plane flys great, its just lacking in the thrust category but that should change.
Have any of you spent some time using differential, My ailerons both travel perfectly evenly but I cant really tell if I need any differential because my virticle is only like 10mph and it slows down when I roll.
