ORIGINAL: dignlivn
bfbcacid
Thanks for that! I spent at least 6 trips un doing the canopy and adjusting tonight. I am getting
this NEW 4n1 close, but i'm still not happy but thats what makes it a challenge. I still hate the tail
set up ( stock one ) on these birds.
Zoo
Is it possible to have tooo much + pitch ?? i don't have a pitch gauge (yet)
or that may be one of my problems.
Bob
dignlivn
This little mod may help you.... Take a drill bit a bit bigger then the size of screw driver you are using to adjust you gain and propor and make two holes in the side of the canopy level with the pots you are adjusting. Then use the holes to adjust 4 in 1 and no more taking the canopy off to adjust... I saw this on the videos I found and posted on this site and man it saves some much time..
I read that too much pitch is a bad thing in non throttle up mode I have about 9 degrees of pitch but I heard that 11 degrees is where you want to be no more then 11... Just a note... Being I am still a beginer please take this advice as so.
Thank You,
bfbcacid
