RCU Forums - View Single Post - really bad radio glitches while running...
Old 07-22-2006 | 05:56 PM
pe reivers
Default RE: really bad radio glitches while running...
HT stands for High Tension. It is the coil and plug wire which generate pulses of about 20,000 Volts, (including the plug cap). It must be completely shielded and the shield must be connected to earth.
Some dispute is going on if both ends must be connected. I did, and it works fine.
