engine performance - ZDZ vs 3W: Help me build this database.
Choosing an engine is difficult without information independent from the engine manufacturer/dealer network. Different criteria are often used in claims to garner or protect the market share. Collectively, we modelers have the hard data to help each other with the data necessary to evaluate available engines before purchase. The top end engine competition appears to be between RCS/ZDZ and 3W. Help me build this database for our own collective use. While engine rpm varies with propeller, atmospheric conditions etc., this measurement can be contributed by most of us and the range of performance can be listed as a range. This information is a better indicator of flight performance than listed HP or calculated thrust. This basic information can then be used by individuals as they wish.
Please evaluate the data listed on the table and help me correct the information listed below. In addition, please send me (email) engine performance data and I will add it to the table.
Single Cylinder engines
Engine . . . . . . . . . . . .Wt.(lbs) . . . . . . Hp . . . . . . . . . . RPMs/prop
RCS 140 . . . . . . . . . . . . 2.0 . . . . . . . . 2.9 . . . . . . . . .18x8 MAS; 7200
(22 cc)
3w-24 . . . . . . . . . . . . . .2.65 . . . . . . . .2.5 . . . . . . . . . 18x8 MAS; 8000
. . . . . . . . . . . . . . . . . . . . . . . . . . . . ? . . . . . . . . . . . .18x10 MAS; 7200
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18x10 APC; 6900
RCS 180 . . . . . . . . . . . 3.25. . .. . . . . . 4.0 . . . . . . . . . 18x8 Zing; 7800
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18x8MASS; 8000
ZDZ-40 (rotary valve) .3.15 . . . . . .. . .4.8 . . . . . . . . . .20x10 Mz; 7400
. . . . . . . . . . . . . . . . . .. . . . . . . . . . . . . . . . . . . . . . . . . 20x10 Mjz; 7600
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20x10 MASS;7000
3W-42 . . . . . . . . . . . . . 3.97 . . . . . . . . 4.0 . . . . . . . . . 20x10 MAS; 7400
ZDZ-50 . . . . . . . . . . . . 3.37 . . . . . . . . 5.7 . . . . . . . . . .22x10 Mz; 7000
3W-50 . . . . . . . . . . . . . 4.36 . . . . . . . . 4.8 . . . . . . . . . .22x10 Dyt; 7500
ZDZ-60 . . . . . . . . . . . . 3.96 . . . . . . . . 6.5 . . . . . . . . . .22x10 Mz; 7300
3W-60 . . . . . . . . . . . . . 5.32. . . . . . . . .6.0
3W-70ius. . . . . . . . . . . 4.75 . . . . . . . . 6.5
3W-70 . . . . . . . . . . . . . 5.32 . . . . . . . . 6.5
3W-75ius . . . . . . . . . . . 4.75 . . . . . . . .7.5
3W-75 . . . . . . . . . . . . . .5.32 . . . . . . . .7.5
ZDZ-80 . . . . . . . . . . . . .4.29 . . . . . . . .8.5 . . . . . . . . . .26x10 Mz; 6500
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .26x10 Mjz; 6700
Mz = Menz std; Mzu= Menz ultra; MAS = Master Airscrew Classic 4, MASS = Master Airscrew Scimitar, Dyt = Dynathrust. Mjz = Mejzlik, Zing = Zinger wood
Thanks Elson
