Amp Meter ??
I would like to know if I can run this arrangement for setting up servos using the Equalizer II. I will have the first servo installed in the surface, have an in-line AMP meter in-line, and have it mechanically correct for the neutral position and the throw. The second servo will be plugged into an AMP meter, then plugged into the receiver and then tuned mechanically to match the first servo. For fine tuning using the Equalizer II can I have both servos plugged into an AMP meter, then plugged into the Equalizer II and then plugged into the receiver? That would allow me to fine tune the endpoints in each direction while watching the AMP meters.
