RCU Forums - View Single Post - elevator offset, cg issue?
Old 07-22-2006 | 07:59 PM
bldrums's Avatar
bldrums
Default RE: elevator offset, cg issue?
Check out the thread on the Seagull Decath. I had to change incidence, build in thrust angles and add 2 degrees of washout ( which is a slow process on a finished wing ) Now my Decath with a Saito .91 is a dream.
