RCU Forums - View Single Post - MGT Engine Question
Old 07-23-2006 | 10:35 AM
Bria1
Default RE: MGT Engine Question
You should be able to turn the flywheel in the direction the engine rotates when running without the starter shaft turning when held. It sounds like the 1-way bearing may be sticking. Pull the pull start off and check the 1-way.
ORIGINAL: think20
u cannot move the flywheel while holding the starter shaft...i also opened up the clutch assembly and everything looks to be intact. Is there anything specifically i should look for?
