10 X Programming Question
HI
Is there a way to disable my stearing servo when I raise the gear. My nose gear wheel is very close to the servo and I wanted to see if when you raise the gear using the gear switch you could do a mix to disable the servo and then when you lower the gear the servo would be active again. I have the nose gear on aux 4 mixed to the rudder now.
I am using the JR 10X
Thanks so much
Bill
