RE: Evolution 58 problems?
greyhound man,
I can only think of three things that would cause the problem. First pull the plug and make sure the piston crown is ok. Try a spare plug. I have seen plugs leak before. You can apply some oil to the plug insullator and turn it over to see if it bubbles. Also the adapter should be checked. If it isn't this, it has to be a ring issue. Good luck.
Dave
