See if it locks up one direction and freely spins the other. You could also clean it with some nitro cleaner and try looking at the plastic cage that holds the needle bearings to see if it looks damaged.
ORIGINAL: think20
what should i look for when i take out the one way bearing? The high pitch noise will be heard the second i start the engine not just while running it
