RCU Forums - View Single Post - genesis plastic dive shafts
Old 07-23-2006 | 10:26 PM
The Real Dogman's Avatar
The Real Dogman
Default RE: genesis plastic dive shafts
Thank you.
Yes I have tested it both on and off track. It helps alot!! Especially when I do doughnuts keeps it more stable and all fours on the ground. Handling is alot more predictable on the track!! The trick is to use 2mm wire!!! I am looking for 3mm wire to test that..
Acouple more shots up close, and one of an old body just to see what it looks like
ID:	495936   Click image for larger version
ID:	495937   Click image for larger version
ID:	495938   Click image for larger version
