#1. I cant seem to get the trim to work at all on my Flash 5
Throttle Channel. The other channels adjust fine though. Anybody else have this problem?
#2. I recently tried to mix aileron and rudder on this radio but ran into problems. When I programmed in
positive numbers it would work only in one direction. In other words, when I gave it right aileron the rudder would also move right. But when I gave it left aileron the rudder did not respond. Programming in negative numbers had the opposite effect.
Eliot
