RCU Forums - View Single Post - F-16 completed
Old 07-24-2006 | 08:40 AM
FalconWings's Avatar
FalconWings
My Feedback: (57)
Default RE: F-16 completed
Pdero Muriente, no jodas? Is that you?
That is your Falcon on those pics!! I do have your name on a decal that was supposed to be placed on the nose gear door, but I opted for the 50th Anniversary decal.
Wow, la vieja guardia. We had some good times. I used to work next door from you at Comm/Nav (under "El Nene").
Saludos,
Pinky "Rosado"
Eddie, I used Top Flite Flat Clear. What I do is I warm the can using a Heat gun (but not too much) then shake it a lot and it comes out very even. I apply several light mist coats, then e heavy one, then wet sand using 1000 grit.
