ORIGINAL: av8tor1977
Since I always convert to electronic ignition, I have often taken a hole saw and cut the middle of the magneto out and used it behind either a commercial prop hub, or one that I make myself. A commercial prop hub is only around $20.00.
AV8TOR
one of these days you will have to post a how-to for installing an electronic ignition with some pictures. i have wanted to try doing that but am intimidated by the process.
