Check the turnbuckle from the upper arm to the upright. You may have to tighten the turnbuckle to shorten the distance of the top of the upright.
I also looked into that, but when I shorten the length, the...camber (I believe its called) looks to be WAY to much and the tires are almost running on the inside 1/4.
