RCU Forums - View Single Post - pitts muffler coming loose.
Old 07-24-2006 | 11:25 AM
bubbagates's Avatar
bubbagates
My Feedback: (32)
Default RE: pitts muffler coming loose.
Use a big flat washer then a lock washer on top of that on both bolts. You can also change out the bolts to a better brand. I have found that between lockwashers and good grade bolts, I do no use locktite.
As was mentioned, locktite will not stand up to the heat and the high temp stuff will make it impossible to remove the bolts later on
