Delta plane airfoil
Well then what would be the effect of leaving the delta plane design and going to a simple low aspect ratio, high taper wing with no sweep or even a swept forward wing?
Is it possible to reduce tip vortices on delta planes in a meaningful manner by using some sort of tip plate?
