Most times, you have to pull the liner out of the cylinder to get the rod off
the piston. You could do the de-glazing with the liner still in, if that was the case....
....but you must clean it up good before you re-install it in either instance.
Here's some engine technique.
http://www.raptortechnique.com/enginebearing.htm
