Delta plane airfoil
Down thrust on the engine stays the same: lower the shaft of the engine. Do you really need down thrust on that delta?
With right and left thrust it is the other way around, as the engine is spinning in the other direction when viewed from the front of the plane.
As for the AC and CG question, I don't know. What plane are you building? Maybe there's someone around that has built one too.
