You can build a cnc balsa plane part cutter!
Oh, ok. Multiple passes. yes, I can do that with aceconverter. I haven't tho, I just cut in one pass full depth. You find it does a better job that way?
I have version 8.1. Do you use wire or mill? I have a tutorial but it's version 7 so it's confusing ansd slightly different. If I sat down and worked on it I would probably be fine.
Eric
