RE: Replacing piston and sleeve
Does anyone know what the part number for the .18 piston rod is I was reading the original post about the conversion and it said I should also get the .18 piston rod as well. I just want to make sure I get everything at once.
(Edit) Also where are you getting these part numbers from so I don't have to keep bothering you guys for them sorry for the inconvience
