RCU Forums - View Single Post - Poulan 46cc/S&S Electronic Ignition
Old 07-24-2006 | 11:10 PM
TIGITRIGHT
Default RE: Poulan 46cc
Well Iv drilled,taped and installed the pulse nipples in the carb and the block.Tomorrow I will be getting the aluminum plate to fab the manifold base.This will have a heat shield of plywood or some thick gasket material like automotive carbs use between the carb and manifold.Will post pics as I go.[sm=thumbup.gif]
ID:	496510   Click image for larger version
ID:	496511   Click image for larger version
ID:	496512   Click image for larger version
