So you only cut the supports in front of the battery, not under it, right? So the battery moves forward about 1/4 inch (6mm)? Anyone know of a glue that will let you pry it apart again if needed?
ORIGINAL: eiwel
Chris
If you pry the nose apart (it's only glued together) you will be able to see the battery. I cut out the foam pillars on both sides of the plane to the front of where the battery was and gently moved the battery forward as far as I could.The battery is held in with two sided tape so you'll have to wiggle it a bit to move it forward.It will only go so far forward as you will see.If you need to you can use white glue to put the nose back together but sometimes the nose will go back with the old glue.It should glide pretty good and give a decent level flight.
