[quote]ORIGINAL: skiman762
ORIGINAL: 2slow2matter
When you did the outside loop,
He did an inside loop from the inverted position if I read it correct he was inverted and and gave it up elevator to do a half loop out
Sorry,
To me an outside loop puts the canopy to the outside of the loop--with negative G forces applied to any "pilot" onboard. An inside loop puts the canopy to the inside of the loop, with positive G forces applied to any "pilot" onboard. It doesn't matter if it's a half loop out or not, it's still an outside maneuver, with negative G forces. What he really did was to give "down" elevator--which in turn (being inverted) caused the plane to rise up into the loop, but all of that is trivial in trying to help him understand what he did wrong. It was an outside loop, by all definitions--nice try, though....
