RE: ST body
Frumpy,
Here you go, when I spoke to the vendor he said that the long post could be attached to the front shock towers. If you look closely at the shock towers there are holes that the post could be attached with 3 or 4 mm screws and bolts. Since I had a front bumper it was easier to mount the body post that way. When I fitted the body I trimmed out the front side post so all I had was the rear. Just put your drill bit through the body holes and drill the holes through the black molding that's attached to the chassis. Here are the pics.
C-One
