RE: Red Hawk controllability
sd I fly micros, aeroaces, everyday. I found the controls on the redhawk different enough to give me grief. However, if you look at your control surfaces you can see that there is not much movement. That is probably why there is so much motor. I am going to put a return spring on the throttle though. Replacement parts are cheap for the 'hawk.
