how to take off
you have to check your balance and when you re try to take off you have to gain as much air speed as you can and when ready to be air born ease back on the elevator do not DO NOT put all the elevator up if you use to much elevator for take off you could loose air speed very fast and you wil stall and if you stall it will be hard to pull it back up because of the low altitude.
GOOD LUCK
