RCU Forums - View Single Post - Nitro Rustler .15 engine problems please help
Old 01-02-2003 | 05:27 PM
jeeptuff
Default Nitro Rustler .15 engine problems please help
you might want to check if you can turn the engine over by hand at the flywheel.. Or next time you go to fire it up, loosen the glow plug about a half a turn and try that, if it fires and/or turns over easily then just high compression. If it does start with the plug broke loose keep it running and sniug up the plug and let her rip.
