RCU Forums - View Single Post - Ignition Interference Problems
Old 07-26-2006 | 05:39 PM
  #31
srm99
Default RE: Ignition Interference Problems
ORIGINAL: mglavin
ORIGINAL: srm99
i found my problem or problems i think
1 x hitec eclips 7 modual was a litlle off feq now adjusted
2 x reciever antenna wrong lenght from factory new installed
3 x the best for last battery was rubbing on landing bracket made metal to metal contact to the outside off 1 cell . better padding and location
Well done,
The TX module being off frequency suggests and supports the OEM's claim is a valid requirement after crytsal change outs, as in your case...
How did you ascertain the RX antennas were shorter than required and or desired by the OEM? Its unlikely they were shorter than required IMO.
The battery and gear metal abrasion could have been a BIG problem.
The crytsal had never been removed from the day a buy and the anttena all are done at tune length to create the maxium gain it was about 4inch shorter than standard why i do not know i did not cut it and i agrree the battery is most likley the main cause but i count my self lucky i found somthing i am still going to get a jr 9xv2 to use on my big plane and i thank everyone for the help even when i was hot under the collar .
